Hi,
New to this forum.
I'd like to covert my Stumpjumper ST 2019 to a Stumpjumper with more travel. I was wondering where to buy a yoke for that and what suspension set up would you go for.
Hi there!
You can get one from Bike Yoke that will allow you fit a shock of your choosing, but I’m not sure you can increase the rear travel. Someone may prove me wrong!
Cheers....
you can just fit the standard LT stumpy yoke and any shock.
try the longer forks first though as you may like it with just them
Thanks, will do.
Cheers...
The bikeyoke part was for previous versions of stumpy, as others have said for the 2019 version you can just buy the linkage from Specialized, it's a 50pound part, you then need a new shock to fit the 210 x 50 {if 29er} dimensions. you can also use a 210 x 52.5 or 210 x 55 for mooooore travel
Grab a coil shock for the Stumpjumper version you will then have 2 very different set ups
