Another dull bearing thread ahoy. Just bought a 2012 carbon Stumpy and there is a bit of lateral play in the back end. I've stripped it and all bearings turn OK so guess they just have lateral wear (this may not be an actual term). They will need replacing sooner rather than later, what's the current consensus on best bearings to go for? I would rather spend a bit more if it's worthwhile to lengthen replacement intervals. Looking at the Enduro Max set from MBB for £70.
No doubt this has been discussed to death all over the web but at least on here I know [s]which idiots to ignore[/s] who is likely to give sensible advice. Ta!
