Looking to see if on a 2012-2014 Stumpjumper FSR Large frame, if you can lower a 420mm reverb all the way down so the collar sits on the seatpost clamp. I'm looking to upgrade frame/bike but need the above info.
Thanks people
I have a large Stumpjumper and a 420mm Reverb, the answer is yes.
However, you'll need to route the hose externally or have the port drilled out slightly, as the Stumpy frame can only accept a 4mm cable, not a 5mm hose.
Thanks for that, should be ok as I have an old externally routed reverb that I could use.
Just another thought, looking at Evo model, would it still be the same.
The evo front triangle is the same as the non evo one as far as I know, the magic happens around the shock 😀
What PJM was getting at is that you can run a dropper remote through part of the top tube, it exits by the shock. Unless it's carbon you can't use a stealth one without drilling holes in the frame
Both the alu and carbon Stumpy frames have a dropper remote port that is ever so slightly too small for a Reverb hose (it enters just behind the head tube and exits around the rear shock), but fits the slightly smaller Specialized Command Post cable perfectly.
Thanks guys,
