Stuck RF X-Type Cra...
[Closed] Stuck RF X-Type Crank - how to get them off
4 Users
I've got a set of RF Evolve XC with the self extracting system.
The bigger 10mm hex-cap is in place but the 8mm crankbolt won't budge.
Tried soaking it in WD40 then using a long'ish bar on the 8mm hex key to move it, but it won't budge.
Any ideas?
Posted : 08/07/2012 4:01 pm
Use a longer bar. 🙂
Posted : 08/07/2012 4:10 pm
 mart
My first reaction would be to remove the outer extractor cap and see if you can free it a little. Then re-tighten and refit the extractor? Grease the inside face of the extractor too I reckon.
Cheers SSS 😉
mart - it won't budge in either direction
Posted : 08/07/2012 4:12 pm
On a serious note.
I'd use a long breaker bar and a short allen socket in this situation.
Then you can get some propper leaverage on it without fear of it slipping.
Posted : 08/07/2012 4:16 pm
 mart
I'm stumped then Steve.
Posted : 08/07/2012 4:19 pm
I had the extractor cap snap on me which meant that I couldn't get a normal extractor in as the extractor was still threaded into the crank arm. I think the best thing to do would be remove the extractor cap and then get a bigger bar on the 8mm bolt, I now use a 2ft bar for loosening the 8mm bolt and a torque wrench to tighten but I will never use the extracting cap.
Posted : 08/07/2012 8:28 pm
See. Like i said. Bigger bar. 😉
Posted : 08/07/2012 8:48 pm
