Stuck reverb hose, ...
[Closed] Stuck reverb hose, in internal routing
2 Users
Hi chaps,
I've managed to get my reverb hose stuck in the internal routing guide, by pulling out backwards by mistake - so the end that goes into the dropper is jammed in the internal guide.
I've tried pushing it back out, a lot, with no joy. I've also tried yanking it to break the internal guide - but again no joy.
Has anyone got any ideas how to get it back out?
Here's a photo to explain it...
It's this internal guide, with the reverb end stuck...
Posted : 11/01/2019 5:53 pm
all I can suggest is a flexible claw grabber tool from somewhere like machine mart, though how successful it'll be if you've really jammed it is anybody's guess.
Posted : 11/01/2019 7:00 pm
That's not gonna be strong enough unfortunately.
So far, I've tried 18 and 24tpi hacksaw blades attached to dowel, a Stanley knife blade the same.
Tried hooking with a loop of cable.
Gonna try to see if I can thread the end of the connectamajig nut onto the threaded barb, with a bar attached.
This is definitely not easy!
Posted : 12/01/2019 6:03 pm
Well, fixed it! Big thanks to Nic at Fallline Cycles in Peebles, we bounced a few ideas around and he had a great idea about using a connectamajig nut.
If anyone has this problem in the future (which I doubt anyone's dumb enough to do this).
Here's what I did...
I cable-tied a 35tpi hacksaw blade to some dowel, then glued a Stanley blade to the end. I cut the rubber boot off the internal routing, which exposed the barb's thread, then removed the blade.
I then sawed a cut in the internal routing hose.
I got the nut from a connectamajig, sawed it in half, then chamfered some dowel of around 7mm, then drifted it in, and glued it in place.
I then took a 6.5mm wood bit, and drilled out the middle of the dowel.
I screwed the tool onto the exposed reverb barb thread and pulled. The internal routing snapped clean off and the hose came out.
Win.
Posted : 12/01/2019 8:00 pm
