Stripping xt chains...
[Closed] Stripping xt chainset apart?
6 Users
Anything I need to know, having a few chain skipping moments and I think it's down to having a bit of dried grass stuck around the bolts. Is it a torx key or Allen key to undo the bolts. ?
Posted : 10/08/2012 2:59 pm
Torx............................you can do it with an Allen key but it takes ages and alot of swearing and you won't be able to retention them after wards 😆
Posted : 10/08/2012 3:01 pm
Torx if they're the bolts that came with the cranks. Surely you can just firk the grass out with a small screwdriver?
if you can get the grass out without removing the rings then i would if i where you. getting them undone can be a PITA but getting them tight again without the proper tool to hold the back of the ring bolt can be even worse.
Posted : 10/08/2012 3:04 pm
Torx - and I think Shimano use a mile long bar to tighten them up at the factory too 👿 best get a piece of wire or screw driver to clean them out if you can
Posted : 10/08/2012 3:07 pm
cheers guys, think i might try getting it out with a small screwdriver first, its pretty well stuck in there, can see it taking some time....
Posted : 10/08/2012 3:15 pm
Torx 30.....do not use a T25 as it will strip them.
PaulD
Posted : 10/08/2012 3:20 pm
managed to get it all out..... with an old knife and fork of all things!
Posted : 10/08/2012 4:01 pm
