Stripped thread on ...
[Closed] Stripped thread on XTR Crank arm, can it be salvaged???
4 Users
Hi
Stripped the thread trying to remove the crank arm (Hence the request on the classified) Is there any way of removing it without scrapping it?
Thanks
Posted : 30/11/2009 6:33 pm
 nonk
gear pullers i reckon.then put a helicoil in.
Posted : 30/11/2009 6:34 pm
Dunno if you can get helicoils in that size - is it not an unusual thread? A threaded insert could be made by an engineering shop id a helicoil is not available.
Ball joint splitter to remove the arm
Posted : 30/11/2009 6:41 pm
 nonk
good call tj the gear puller might make a bit of a hash of things.
Posted : 30/11/2009 6:46 pm
Did the same thing to my race face cranks and had it sent off and an insert was installed by the lbs (i think they outsourced the job mind).It cost about 40 quid . Deffo worth a try.My crank is still going strong 3 years later
Posted : 30/11/2009 10:01 pm
