Anyone having trouble getting the OS map flipper (from veloviewer) to work in strava? Not working for me in any browser at the minute - something up with my settings or has it been withdrawn?
I found the same, and couldn't see any reports on t'interweb about it.
However, I have found a workaround - if you activate the flipper, and then on the Strava map select satellite maps, it will draw the OS maps over the satellite imagery.
No idea why/when the change was made...
Nice one gareth, that works for me. Civilisation is restored - strava routes on OS maps 🙂
Anyone found a way for this to work with the global heat map?
I don't know nickjb, but it definitely used to work with the heatmap as I used it to plan some routes earlier in the year.
It must be a simple script, so a STW IT person would prob understand what the problem is.
Has the Strava map flipper packed up again for anyone else?
Even the 'satellite' map workaround has stopped working for me :o(
I noticed it had stopped working about the same time. If you delete your existing mapflipper bookmarks, then re-make them from the VeloViewer page here:
http://veloviewer.com/mapFlipper
Then they should work again.
Hope this helps.
