Strava - eh?
[Closed] Strava - eh?
9 Users
So last night a TT recorded 246w average on my garmin via a powermeter, uploaded to Strava as 236w.
Today, an outdoor ride at 226w & 29.9kmph on the garmin uploads as 213w 28.9kmph.
Why's it wrong?
Posted : 05/05/2016 1:21 pm
It's about 3% difference. Both would probably have some form of accuracy tolerance and considering you're relying on things a long way away to pinpoint your position I wouldn't think 3% would be too bad?
Posted : 05/05/2016 1:39 pm
you wouldn't be complaining if Strava was 10watts higher each time 🙂
Posted : 05/05/2016 1:41 pm
Too right I wouldn't 😀
Posted : 05/05/2016 1:47 pm
But Strava isn't measuring power, it's merely taking the XML from the Garmin's recorded data. I can only imagine it's not taking all of the data points. I've noticed the same.
Posted : 05/05/2016 1:48 pm
have Strava/GPS fun when riding with others and see how different your distance and altitude gains are.
What Stevied said, if each system (power, GPS) as a +/-2% error then you could end up 4% out.
Posted : 05/05/2016 1:49 pm
You get massive variances in altitude too, last night my garmin recorded 669m and my S6 579m on the same route
Posted : 05/05/2016 1:51 pm
Yes, but Kryton57 isn't using 2 different GPS devices - it's the same one.
Posted : 05/05/2016 2:04 pm
It's the same dataset being interpreted by two different web interfaces. I've noticed Strava generally seems to be lower than Garmin for averages, it must work them out slightly differently.
Posted : 05/05/2016 2:08 pm
It's not "wrong" as such both use different algorithms to interpret the data.
Lots of info about this on the strava forums etc
Posted : 05/05/2016 2:12 pm
Just for the record the Garmin numbers are being read of the device pre-upload, not Garmin Connect.
I guess its in my favor should any competitors underestimate my massive power potential... 😳
Posted : 05/05/2016 2:16 pm
