Straight pull 28H F...
[Closed] Straight pull 28H Front hub or conventional 28H hub?
8 Users
Not used straight pull spoke wheels before, so unsure what to do?
Posted : 21/02/2017 9:55 am
 br
Try buying both straights and j-bends.
Then you'll stick with j's 🙂
Posted : 21/02/2017 9:58 am
Depends what you're using the bike for, if you're about to head off round the world on a fully loaded touring bike, it may be wise to check availability of spares in the countries you intend to travel through.
I have straight pull spokes on one bike, can't say I've noticed any difference tbh.
No problems at all, 130kg rider on a 18kg full sus ebike, so nowhere near lightweight.
My wheels are dt ones, they were about £200, so not exactly expensive either.
Posted : 21/02/2017 10:05 am
^^ B R may have a valid point lol
Posted : 21/02/2017 10:06 am
No problems with straight pulls on a couple of sets of wheels. I built mine so just ordered a few spare spokes just in case.
Posted : 21/02/2017 10:07 am
I was going to look for a conventional bub but have been offered a straight pull hub so just wondered.
I can't build wheels so would need to get someone to do that for me.
I was probably going to get DT spokes from Rosebikes whichever I go for.
Posted : 21/02/2017 10:19 am
Far less likely to break a straight one though?
Posted : 21/02/2017 10:29 am
Cheers stevied another option.
Posted : 21/02/2017 10:44 am
@ molgrips, I believe thats true, but it wouldn't be much comfort when you've broken a spoke halfway across russia and the nearest shop has never seen a straight pull spoke.
Hope for the best, plan for the worst
EDIT: of course, would be much less annoying on an hour playing in the woods.
Posted : 21/02/2017 11:20 am
molgrips - Member
I've snapped a few spokes over the years and none at the J bend part. Most seem to snap about 50mm from the rim
Posted : 21/02/2017 11:34 am
Conventional, because straight pull has no real world benefits at all, and some drawbacks. The only reason to use SP is if a wheelset you want comes with it as standard, and even then, it's a black mark.
What's quite funny now is that at the same time as we're being sold boost as a standard because it has better triangulation which supposedly builds a usefully stiffer wheel, we're also sold SP hubs which generally have lower flanges and therefore worse triangulation. It's almost like it's all bullshit.
molgrips - Member
Nope.
Posted : 21/02/2017 11:44 am
Go conventional unless you really, really want straight pull.
I have both and notice no real world functional difference between them but as soon as I want to change a rim it is more hassle than it is worth to calculate spoke lengths and obtain spokes. My future is full of 32 holes with J bend spokes
Posted : 21/02/2017 11:56 am
