Stooge forks
[Closed] Stooge forks
2 Users
If you are not using the OE steel fork on the Mk3 what is the next favourite suspension or carbon?
This is for bikepacking not hooning.
Posted : 29/05/2019 9:29 pm
I've got Rockshox Reba 120mm somethings. Compression adjustment with lockout and rebound adjustment. I set the rebound pretty slow but with a fair bit of pressure. I'm a fat biffer so I blow through the travel easily if they are too soft.
I like the high front end that it gives with Stooge Moto bars which suits me for ride up, down and along. Unlocked for reduced trail chatter and remove the big hits without diving too easily.
Posted : 29/05/2019 9:40 pm
Oh, forgot to add that I'm going to try it rigid once the 85mm Junker bars arrive. They will give me the same height front end as the boing forks.
Posted : 29/05/2019 9:42 pm
