Hi lads woukd stendec easy glide be ok for pivot bearings ? It’s waterproof and I read on this site that it is good for bearings
I'd go for something a bit thicker myself Mobil xhp222 is my choice for pivot/ wheel/ pedal/ BB bearings.
I use Stendec for dropper posts, fork and shock seals as it's a bit thinner and less sticky.
Cheers mate where’s the best place to buy it plz? Done a search but it’s coming up£20 a tube.
I like Superlube grease.
I think the stendec easy glide is better suited to sliding surfaces such as forks and droppers, Google 'red n sticky grease' a 1lb tub is about £8 and good for bearings, there's an xtra heavy duty grease by same company or the moly type grease for cv joints would be good too for pivot bearings as they don't usually rotate much.
Grrr, stupid forum 'error try again in 30 secs' double post value my privacy 2 times while trying to post nonsense!!!!
Cheers mate 👍🏻
