So after selling my Stumpy frame and building up my Bird Aeris, the steerer on my forks is right on the limit with no spacers.
The head tube on the Bird is quite a bit bigger than the Stumpy.
This has left the front end a bit lower than I would like!
Apart from a new CSU, have I any other options?
If it's only the bar height that is lower than you like then how about a stem with a bit of a rise in it - or riser bars?
Riser bars or zero stem or even flip a stem with more rise/ fall.
It can't leave the front end lower than it was, you just have fewer spacers...
Due to the size of the frame, I'm running a 35mm stem with a Renthal Fat Bar Carbon.
Can you get a higher rise stem at 35mm? Also quite like my bars and think they are 20mm rise currently. Might be a bit costly to change them (still cheaper than a new CSU I suppose!)
I've put up with it for a couple of months now, but after 3-4 hours I get a bit of a stiff neck. Was just thinking higher handlebars might help.
njee20, sorry I don't understand what you mean. I want to get the bars a bit higher, not the front end higher if that makes sense 🙂
You have just swapped spacers for head tube. Bars will be the same height.
Your stem is probably 35mm long, not high.
You could sell the 20mm bars and buy some 38mm raise Renthal Carbons.
But it's a different frame and totally different geo/size.
It's a lot longer than the Stumpy and the reach etc is different. What I mean is what worked on the Stumpy, isn't working on this, but the steerer is too short for even 1 spacer.
Sorry about the rubbish explanation 🙂
I know, the stem is 35mm long. What I was asking is if 35mm stems were available with more rise due to how short they are?
Clamp on steerer extender? Not very gnarrrr, looks pants but very cheap and they do actually work. Would at least let you know how the fit works out before splashing out on new CSU / bars / fork etc.
I work with a heavy 6'7" Wigan knuckledragger who needed one to make his bike "fit" and hasn't managed to break it yet.......
If you do a comparison [url= http://www.yojimg.net/bike/web_tools/stem.php ]here, you can see what's likely to be close.[/url] A Ritchey 30deg 60mm stem might be somewhere near??
Check the height of the steerer part of the replacement stem to your current one also, you don't want it to be much taller than your current one.
Something like this?
[url= http://www.silverfish-uk.com/ProductDetail/8765/15478/OnOff-Stoic-FG-Stem-20mm ]http://www.silverfish-uk.com/ProductDetail/8765/15478/OnOff-Stoic-FG-Stem-20mm[/url]
Bars will only be the same distance from the front axle. Stack, HT angle and bottom bracket height will determine how high the bars are in relation to the rider. Some other factors will also come into play to some degree. Suspension sag fr/rr, seat tube angle and so on.
Ate you likely to lose a load of cash selling yours and buying another fork (sh or new) with longer steerer? Or as suggested, higher rise bars or stem.
Cheers all for the suggestions.
I was always wary of the steerer extenders to be honest, not sure why.
Twisty, when I bought this one, I tried to make sure it wasn't as tall as my Renthal one I have! Guess it wasn't low enough 🙂
Like the look of the Mondraker stem, but bloody hell they're pricey!
Ghostlymachine, There's a few factors for sure! Missus has said she'd have my fork and I should get a new one, so that's an option. Steerer should be long enough for her.
That comparison tool is handy! The stack height on my current stem is 33mm and that's right on the limit. My Renthal stem has a 6deg rise (50mm), but the stack height is 40mm, so it's too much.
[i]You have just swapped spacers for head tube. Bars will be the same height[/i]
This, but if you really mean:
[i]But it's a different frame and totally different geo/size.[/i]
Then I'd have thought it could be a combination of options, why not buy a cheap high-rise bar to see if actually having the bars 'nearer' you actually works - it could be you need to move the saddle forward, or slightly change the angle, or roll the bars or...
Good points b r.
I've tried rolling the bars back a bit and that did help. Saddle is another option, I think I could move that forward a little bit and try it.
I'll try all the cheaper options first before I do anything else.
And steerer extensions, at best, are an extra point of failure, creaks and being a pain in the arse.
At worst they will damage steerers. And teeth.
For short term comparison / tweaking of bike fit, stuff like steerer extenders cause no problems whatsoever. I'm not suggesting he keeps it on forever or goes downhill racing with it!
I had a similar problem and after researching stem stack heights (I think there was a Ragley stem that has a low stack height) I ended up buying some s/h forks and selling my old ones. Pretty much broke even and the bonus was that I got rid of the dreadful early Fox 34 CTD's 😛
Paul B, keep saying things like that and I'll end up getting the go ahead for shiny new forks! 🙂
I don't think I'll try an extender as I've just started getting better at jumping and started getting fond of my face!
I think I'll end up living with it until I can get some new forks I think. Missus will have the Yari off me and I might try something else...
johnw1984 - Member
Good points b r.I've tried rolling the bars back a bit and that did help. Saddle is another option, I think I could move that forward a little bit and try it.
Are you sure it's not too big?
Cheap risers would be a good bet to get it right, flog them and then get the ones you want
You don't want a 35mm stem with more rise. You want a longer stem with more rise (assuming you want the same reach).
Figure out where you want the bars and have a play with this: [url= http://yojimg.net/bike/web_tools/stem.php ]http://yojimg.net/bike/web_tools/stem.php[/url]
Drop your saddle and fit shorter crank arms?
Same effect but at the other end of the problem
What njee said.
I've had a go at the stem calculator thingie. The frame seems spot on fit-wise, the only problem i have is I just wanted to raise the bars a bit to see if it's more comfortable.
I'll try some of the cheaper suggestions first and go from there.
What headset?
I had this issue when i went from my stumpy to my alpine. I found the lowest stack headset possible and went with riser bars.
[url= http://www.dmrbikes.com/Catalogue/Controls/Stems/Defy ]I had the same problem, got a DMR Defy stem, quality bit of kit[/url]
Hey johnw1984,
I just sent you an email. I might have a solution for you.
philwarren11, it's a Cane Creek headset with a very low stack 🙂
Trailrider Jim, I've actually got that stem saved in my favorites!
What length fork? If pikes and 150mm you could fit a 160mm air shaft for 10mm extra height. High rise bars would be my answer. I assume the reach is increased over your previous bike with the same forks as the bars will be the same height as with that bike.
You could always go with one of these abominations http://www.ebay.co.uk/itm/RaceFace-Diabolus-D2-Stem-2012-Black-31-8-35mm-Zero-Rise-BRAND-NEW-/260946316058?hash=item3cc19ccb1a:g:fB4AAOSwyQtV5LHy
They are 150mm Yari. I don't fancy going 160mm on the front (bike is designed for 140/150).
I'll make a few adjustments I think then eventually just pass this one to the missus and get a new fork 🙂
I'v already got a 0deg 35mm stem. Plus the stack height on that is too high to fit what little steerer I have.
Did you not measure all this before purchasing?
Problem solved surely!
Nairnster, I did (sort of).
The steerer was already cut for my Stumpjumper. I purchased the Bird frame in XL and mistakenly looked at the head tube size for the Large. My heart sank when I put the steerer through the headtube!
I bought a stem with the lowest stack i could find and it is literally on the limit (possibly 1-2mm too short currently). There's about a 4mm gap between the top cap and steerer.
jam, I'm hovering over the buy button on some 2017 Fox Factory 34 150mm.... I'm going to try the Yari on my Wife's bike first, then I'll make a decision.
End of thread.
I'll get flamed for this but, I had the same issue a while back, but I had kept (well not tidied up) the steerer off cut. so cut a nice even piece off that with a pipe cutter and fitted it in place with a deep expander for carbon forks. I had planned to bond it in place but it never moved. the stem clamped either side of the join. And I don't recall dying.
Speshpaul, not to sound "gnarly" etc, but what sort of riding do you do? Do you do biggish drops or jumps/rock gardens etc as well as normal trail riding?
I only ask because I guess it depends on how much strain is going to be put on that area.
When I gave my son a bike he fou d the steerer too short and just placed a length of tube on top, clamped it up and rode it for about a year without any problems s. His brother teased him about "groundbreaking split steerer technology" and he used to treat the bike way beyond it's intended use (sc superlight) without any issues
I won back a few mm by swapping headset parts around- some are very tall, and compatability for top caps is actually pretty good these days.
What headset cover have you got? Might be able to gain 10mm or so with a lower stack cover. You might also find a lower stack stem? Combo of the 2 above may give you the extra you need....
It's already a very low stack Cane Creek and I bought the lowest stack 35mm length stem I could find.
Just treated myself to a new 2017 Fox 34 to solve it 🙂
The Yari is now attached to my Wife's bike (so she's happy).
all this chat of lower headset top caps and such doesnt really solve his issue does it ..... none of that moves his stem any further north.
the right way to do it is a new CSU , I have one of them steerer extensions on my utility bike.... it A looks shonky and B has a silly amount of leverage on a clamp in a direction it was never designed to do. I can live with it as i dont really get gnar on my bike while riding the roads and paths to work and shops BUT i wouldnt not fancy it on my downhill bike for example....
trail_rat - Memberall this chat of lower headset top caps and such doesnt really solve his issue does it ..... none of that moves his stem any further north.
No but it all gives you more room to maneuvre with stem choice etc- going downwards can let you pick a stem that goes more upwards.
I do appreciate all the comments and helpful suggestions, but I think trail rat had confirmed my suspicions.
Everything else seemed like a compromise. Northwind, I was up for the idea of a stem with a bit of rise, but the stack height on most of them was too much.
Solved my problem in the only way I know how. Spending a stupid amount of money on a new fork I probably can't afford 🙂
