I've been trying to get some comfort out of this Cube road bike of mine, and have put about 1.5 cms of extra spacers above the 3cms that are there already.
The thing is, I now seem to have the top of the stem 1.5 cms above the steerer....the pic shows it quite well.
It feels solid enough- no play at all. But I'm terrified it will kill me. Will it?
picture fail.
New stem time
Not good like that need a stem with more rise or a thinner clamping stem
steerer should be above second bolt as an absolute minimum
Not enough steerer in that stem...
Waaaaaaaay outside sensible envelope.
Yes.
"Will I Die?"
Asked so many times, and in this case: "Yeah, perhaps"
I wouldn't ride that. Quite often on road bike the stem has a negative rise, have you tried removing a spacer or two and flipping it over? Other wise get a new stem with a higher rise.
OK- thanks all.
I should say: I haven't rode it like this, it was just an experiment. The stem is already flipped over so that it's got a rise. The idea was to build up the overall height to make it a more comfortable ride, as I've had to get physio to sort out a neck problem on account of it 🙁
I'm thinking the frame is actually too small- despite it coming from a reputable bike shop and getting sized up by them, within a couple of weeks I started to get aches on it. Googling tells me that many Cube owners go a size up-
I'd be using one of these if I were you:
[url= http://www.wiggle.co.uk/bbb-bhp-22-steerer-tube-extender/ ]Steerer extender[/url]
Thanks rob.
