Stealth Reverb
[Closed] Stealth Reverb
7 Users
So every ride it stops working and needs constant bleeding.
its not leaking at either barb and has been bled over and over, usually just a remote bleed cures it but by the end of a two hour ride its basically non functional and I'm now bored of doing it
Anyone any ideas?
Posted : 31/10/2015 7:30 pm
Or is it in warranty? You could send it off for a service if not and you don't fancy a crack yourself
Failing that if it's 31.6, 125mm drop and 380 length sell it to me as I'll strip it and rebuild it.
Posted : 31/10/2015 8:02 pm
Is your (ahem) knob stiff to push in? Maybe the stem doesn't need bleeding but perhaps the cable is trapped, hence the stiff knob. That's what happened to mine so I rerouted the cable and all was good.
Posted : 31/10/2015 8:10 pm
Sorry forgot to say Stealth reverb, its not even 2 weeks old and hasn't worked from day 1 properly
I have read they aren't too hot to start if you have one that's a bugger from the start
Posted : 31/10/2015 8:26 pm
I'd take/send it back for a warranty rebuild/replacement.
Posted : 31/10/2015 8:28 pm
Send it back and will be sorted by fishers
Mine was like that. It was the barb connection at the post end leaking slightly. Reset it and it's been fine since.
Posted : 31/10/2015 9:07 pm
How tight is your seat clamp?
Posted : 31/10/2015 11:04 pm
Seatclamp isn't tight, it works fine after a bleed then progressively drops off over time.
I bled it last night to go out today and this morning it would neither go up nor down.
The lever pushbutton is about halfway and was solid, you can pull the pushlock lever out.
Odd thing is the barb joints are bone dry and not leaking at those points so I'm stumped?
Posted : 01/11/2015 10:13 am
Send it back...doesn't sound right at all.
Posted : 01/11/2015 11:13 am
Hi I have had the same problem, when bled properly the lever should be in the full out position. I had to bleed the lever and put pressure on the syringe to fill the lever assembly fully and extend the lever. without this it wont work.
Posted : 01/11/2015 6:41 pm
