about to order one. Normally take a Large in all riding jackets/tops -how does the Stealth size up ?
chest 41, waist 34, height 5ft 10 and a wee bit 😆
they are quite tight for size but are I think intended to be so as they stretch- I only ever wear a thin shirt underneath even when it is well below freezing. I am 44 chest 36 waist and have a large
I should also say that I did try on an XL in the shop and was advised it was too big- The L is long enough in the arms and back at 6'2"
Im 6'3" 44" chest 34" waist and have an xl, could do with it being a little bit neater in the body but need the length of the xl.
thanks all - probs between a M and L, so will go for the L
I normally take a M in everything but IIRC I needed a L Stealth, especially as the arms are pretty skinny. I'm 5' 8" with 40" chest
thanks Captn - sounds like a deffo L for me, cheers
I found the arms very tight on the large but too long on the xl, I'm 33"and five ten, I went for a gore oxygen instead as it fit better
I'm in a Large too, 6'2" waist 32/34 and chest 42 with skinny build.
Usually only wear it when really cold/wet and then with just a long sleeve skinz-type baselayer.
Found arms on a L too short so ended up with an XL that is too baggy on me at 6ft, 42" chest, so if you`ve got long arms beware!
Captain - that's weird. Also 5'8" but 42" chest (just under 30" waist) and the M fits me perfectly. Cannot rate them highly enough.
cheers all, L just ordered 🙂
