Stava and endomondo
[Closed] Stava and endomondo
7 Users
Can I run both at the same time?
It will be on an I-phone 6 if that matters.
Thanks
Posted : 18/08/2016 12:28 pm
Can you not link the two accounts so that one updates the other? I've done that with Garmin Connect and it works fine, might take a minute or so for the activity to sync.
Posted : 18/08/2016 12:30 pm
Don't think you can link those two services directly, but you have the option of using the Tapiriik site to synchronise the two accounts manually (Free) or automatically (Small fee).
If you had something like a Garmin for tracking workouts, then you can set it to sync to both services as well as Garmin Connect on completion.
Posted : 18/08/2016 12:46 pm
Is there a Garmin Connect app for iPhone? If I use mine on Android it can be set up to update both Strava and Endomondo.
Posted : 18/08/2016 12:47 pm
I just want to run both at the same time for few rides in the most simple way ( if possible )
Posted : 18/08/2016 12:51 pm
Try it? You won't have to move far to find out.
you can run two gps apps at the same time on the iphone.
Posted : 18/08/2016 12:52 pm
I record stuff in Endomondo as I've been using it for aeons, then I use [url= https://tapiriik.com/ ]Tapiriik[/url] to sync stuff one way from Endomondo to Strava.
Posted : 18/08/2016 12:54 pm
What jambo says, I run both Endomdo and Viewranger on my iPhone 6. Note you have to turn on location sevices in the background (as not both apps can be the main active ones at the same time). Also I run endomondo in low power mode so it records gps track data but isn't using tons of power to send the info "to the internet" continuously via mobile data.
Posted : 18/08/2016 12:56 pm
Jambo jambalaya thanks. Huge help.
Thanks guys
Posted : 18/08/2016 1:01 pm
Ok, so just been out and they work together.
Thanks again
Posted : 18/08/2016 5:29 pm
