Stans Rims
[Closed] Stans Rims
11 Users
Do you have to use Stans valves with these as I can't get them to hold air with my current valves?
Ta
Posted : 13/08/2013 11:14 am
I've used the Superstar ones as a cheaper option.
Posted : 13/08/2013 11:18 am
I've not got Stans ones… not sure what mine are I got them for £5 from a mate when my wheels arrived without any.
Posted : 13/08/2013 11:19 am
Just knock up a "seal" out of an old bit of inner tube, works for me.
Posted : 13/08/2013 11:20 am
I've used Shimano and Specialized tubeless valves on them with no issues.
Are you using sealant?
Posted : 13/08/2013 11:21 am
Roval ones work too. But I didn't have good results with Mavic.
Posted : 13/08/2013 11:22 am
Cut the valve from an old tube, do up tight.
Northwind - Member
Yeah, Mavic ones are shaped for the UST rims, suspect they wouldnt' play nice with Stan's rims.
Posted : 13/08/2013 11:37 am
 Kato
I'm using Superstar ones with my Flow's. No problems
Posted : 13/08/2013 1:08 pm
The lump of rubber around the valve can be a problem which is why Stan designed his to be flat here. YMMV.
Posted : 13/08/2013 1:18 pm
Thanks everyone, I've been using 819's so maybe I just need some non mavic one's.
Posted : 13/08/2013 1:25 pm
top tip , if your having issues with valves sealing ....
dod o mastic in the hole and stick the valve through.
Posted : 13/08/2013 2:13 pm
Never had a problem with a valve cut out of an old inner tube, though have had to get a pair of grips out to properly tighten the lock ring thing.
Edit: Had a pair of specialized ones a while back, rubbish as you couldn't remove the valve core!
Posted : 13/08/2013 2:25 pm
