Stans flow tubeless...
[Closed] Stans flow tubeless conversion
6 Users
Okay, i bought a set of flows a months or so back. These are on Hope pro2 evo hubs. As such the rims have the green porous tape attached.
From my LBS's recommendation i bought a stans conversion kit to go tubeless.
But it came with very slim yellow tape. Every video and tutorial i have watched shows or specifies wider tape that covers the whole of the inside of the rim. At 55 quid spent on this kit i will be pretty pi''ed off to have to buy more kit.
Any ideas. Im going down to the LBS for a full idiots guide 🙂 tomorrow but if you guys have the answer then fire away.
Posted : 12/09/2012 3:48 pm
What size tape was in the kit?
IIRC you need 25mm for the Flows
Posted : 12/09/2012 3:56 pm
What kit did you get? There's a Hope one with the wide tape, two valves and two little bottles of sealant for about £20.
Posted : 12/09/2012 3:57 pm
I think stans do different size tape for different rims. I bought the hope flow tubeless kit from crc for 20 quid. It had the correct tape for flow rims, 2 valves and 2 bottles of sealant. That's all I needed. Wrong kit maybe?
Edit-onzadog beat me to it. 🙂
Posted : 12/09/2012 3:58 pm
At £55 it sounds like you got rubber rim strips that you don't need for flow rims.
Posted : 12/09/2012 4:00 pm
looks like its the wrong kit. out came with 2 room strips. slim yellow tape and sealant. winner. 😯
Posted : 12/09/2012 4:04 pm
Can you send/take it back?
Posted : 12/09/2012 4:06 pm
yep, just been on the phone. It's going back tomorrow. Cheers for conforming i wwasn't going off my head 🙂
Posted : 12/09/2012 4:12 pm
Never said you weren't going off your head, just said you had the wrong kit. 😉
Posted : 12/09/2012 4:22 pm
Just to confirm. All you need is 25mm yellow tape and two valves
Just watch the stans video the tape can be a little odd to use if it's your first time
Posted : 12/09/2012 5:35 pm
cheers for the help guys 🙂
Posted : 12/09/2012 9:03 pm
 sp
FWIW a top tip from this very site - use electrical insulation tape, couple of wraps and job done
Posted : 13/09/2012 5:29 pm
