Hi
A mate of mine is building me some 29er wheels and having bought some Bontager tyres off here, he says they are an incredibly tight fit and I mean incredibly!!!!
Other Bontager tyres on 29er Bontrager rims are ok
Anyone else had any problems?
This is 29er-just to emphasise
Steve
Running 29er Crests with Bonty XDX tubeless ready tyres. Didn't have any trouble getting the tyres on at all.
make sure he's dropped the tyre bead into the central channel before fitting.
+1 Good Advice.
Makes a big difference, and also fit the tyre side opposite the valve first and work round, helps give you a little more slack.
I've found Maxxis ok to fit Crest 29er rims - Ardent, Beaver, and Crossmark all ok.
seen lots of threads with crests being a pain to get tyres on - recently got some myself, and yes they are a bit tighter than the 355's they've replaced, but as above - make sure the tyre sits in the central groove and no problem (bonty and maxis tyres on with minimum fuss)
I've swapped 5 tyres today (raining and kids to amuse). Mix of DT5.1, Stans 355's, Crest and FSA 29er, with crossmark, Racing Ralph, Bonty and WTB tyres. Only one I had bother with was an oldish Ardent on the Crest - couldn't get it to seal. Didn't try for long. Everything else went on and up fine with a track pump. You soon learn little tricks to get tyres on and up tubeless.
As above it's all in the technique, I've fitted 4 tyres on Crest rims today (Bontrager 29.3, Schwalbe RR and 2 Conti Race King) and not had an issue getting them on at all. Once you've done a few they really are quite easy.
