Stack height/head t...
[Closed] Stack height/head tube length question
3 Users
If my head tube is 115mm and my stem has a stack height of 40mm will a fork with a tapered steerer of 190mm be long enough?
Will need some kind of reducer headset as head tube is 44mm ID, just not sure what stack height these headsets have
Posted : 20/06/2013 10:20 am
if the fork is 1 1/8" you can get headset cups and bearings that sit within the headtube (assumign fork crown will clear downtube) so stack height of headset would only be a few mm more than the headtube length.
like this;
Posted : 20/06/2013 10:23 am
Thanks - forks are tapered
Posted : 20/06/2013 10:26 am
so you just need to add the stack height of the lower cup - I reckon you'll have enough with the numbers you gave though.
[edit] I shoudl have read the post and I'd hav seen 'tapered' mentioned!
Posted : 20/06/2013 10:27 am
http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=539
This tapered conversion headset for straight 44mm headtubes has a 20mm stack
115+40+20= 175
so you should be fine
Posted : 20/06/2013 10:29 am
Thanks both - looks like the CK Inset 7 has a stack of 22mm but I might use an Easton stem with 36mm stack so yes should be OK
Posted : 20/06/2013 10:32 am
