Cassette s a bit rattly, got it as tight as I dare but it's not nipping up the sprockets. Sunrace mx5. Or have I knackered the threads (probably).
All 11spd road freehubs need a spacer (1.85mm) to run a 10spd cassette.
edit: just checked the specs on the SS site - it's not 11spd road compatible so shouldn't need a spacer.
MTB?
MTB?
Sorry, see my edit. More hubs are now coming with an 11spd road width freehub so assumed it would be this.
Bum. That means I've knackered it.
Nope, I have a set and the 10spd cassette fits fine.
On t'other hand, tolerances on different brands can vary. So why not try a thin (1-2mm) shim behind the cassette, it won't do any harm. The freewheel is steel is it not? So unlikely you've damaged that. Have you tried a different lockring?
