ss chainline how mu...
[Closed] ss chainline how much movement before its no good
2 Users
i have a ss road bike with a 135spaced rear hub and 116 square taper bb. I find the cranks very wide compared to road bike. I was going to try a 110 bb and space out the chainring by 1 or 2mm, i'm assuming 1 or 2 mm wont affect chainline that much.
will i get away with a 108 or 107bb axle or is 3 or 4mm pushing it?
ta
Posted : 03/06/2014 4:03 pm
You'll need to check the clearance of the crank arms on the chainstays so they don't foul. This is the main reason mtb cranks have a greater Q factor than road bikes.
If thats ok, can you move the chainring to the outer position to keep the chainline similar?
Posted : 03/06/2014 4:08 pm
As specific chain set but there is space to put a 2mm spacer between ring and spider
Posted : 03/06/2014 4:20 pm
