SRAM/Truvativ Chain...
[Closed] SRAM/Truvativ Chainset, Am I missing something?
7 Users
Ok, I've just bought a new chain and cassette for my Epic and next months pay was going to support the purchase of new chainrings (2x10). The chainset that came on the bike is a SRAM S-1250. Ive recently replaced the PF30 bb with a new upgraded version following advice from the shop. In the long term I'm going to replace the lot with a converter and XT but thought I'd just swap the rings for now. I've trawled the web as the LBS said they are being screwed by their suppliers and the prices are high.. they werent wrong!!
What am I missing, rings that seem to fit are nearly £90 for the pair!.. I could by a whole BB30 CSet X9 or even X0 for only a bit more.
I'm guessing the stock Chainset is rubbish?... is it worth just replacing the lot, and if so, recommendations? X9/XX,X0 or something else?.. or am i looking in the wrong place for rings?
An no I'm not going 1x10.. I live in Devon! We have proper hills here!
Ta
Posted : 29/05/2015 8:18 pm
Nothing wrong with the chainset - its not exciting but its perfectly good. Certain items like XT are in a price war, and so much cheaper than they probably should be, so buying rings only is not good value whichever way you do it. You could have the same debate about buying XT rings vs. a whole XT chainset.
The downside of the SRAM set up is the 3rd party options are limited so there is a lack of cheaper options there. Its probably cheaper to replace the whole thing.
Posted : 29/05/2015 8:26 pm
got the BCD for the rings?
Posted : 30/05/2015 2:50 am
Try somebody like [url= http://www.sjscycles.co.uk/ ]SJS Cycles, they have a good selection[/url]. Different brands so check with them first
Posted : 30/05/2015 5:19 am
A change of chainset will also cost you for a new bb as well
Praxis works do chainrings for sram but not sure they'd be any cheaper
Posted : 30/05/2015 6:19 am
A quick looks suggests it's a fairly standard 104bcd so should but just about any chain rings
Posted : 30/05/2015 6:21 am
Why would I need a new bb? Can you tell I've never bought sram stuff before?
Posted : 30/05/2015 6:33 am
Ah, ok. Yes I knew that a Shimano cs needs different bb. Just thought you meant if I changed the 1250 to x9 or some thing id need new one. Thanks
Posted : 30/05/2015 9:20 am
 gren
Got an X0 triple chainset on mine and nearly keeled over when I saw the cost of replacement rings - about £80 for a set. Picked up a full set of hardly used ones on ebay for less than £20 and have kept an eye out for cheapo ones ever since.
Changed to a double recently - brand new rings again were £20 from Pinkbike. Lots of people going to 1x makes them come up often.
Posted : 30/05/2015 10:46 am
just checking? are these the 104/64 bcd ones or the 120? There are hundreds of normal rings that will fit.
Posted : 30/05/2015 10:49 am
Proper hills in the Peak District too - and lots of 1 x users. Which means plenty of used on the classifiesds
Posted : 30/05/2015 11:14 am
