Sram XX Single ring
[Closed] Sram XX Single ring
6 Users
Hi,
Can you convert XX to single ring? Thought I seen rings available in a mag but can't find it .
Ta
Posted : 02/05/2013 8:08 pm
How do you mean? 120mm BCD rings, 104mm BCD rings with the Gamut spider that's just been launched, with a XX1 spider & ring, or with the spiderless rings from a number of manufacturers? 😛
Posted : 02/05/2013 8:12 pm
Spiderless XX1-style rings would be my choice. Works are releasing theirs at the end of the month.
Posted : 02/05/2013 8:14 pm
Hi,
My spider is part of crank. Cool if I can get a ring to fit it.
Posted : 02/05/2013 8:21 pm
XX? Spider should unbolt from the inside.
Posted : 02/05/2013 8:24 pm
No its all one carbon piece, crank arm & spider.want to take bothe rings off ie 29/36 off & run o 42 ish.
Posted : 02/05/2013 8:35 pm
Sorry I meant 32 teeth.
Posted : 02/05/2013 9:27 pm
e*thirteen do them,i once had a 37t,have a look on crc
Posted : 02/05/2013 9:37 pm
Not 32 though
Posted : 02/05/2013 9:56 pm
Renthal make a chainring for SRAM cranks.
Might be worth just getting the XX1 chainset though?
Posted : 02/05/2013 10:04 pm
If the BCD is 120mm on the outer ring (which is what I remember) you'll not get a ring that small; that's the minimum size with 104mm BCD without a bit of trickery. That 37t e13 ring might be the smallest you'll get.
Posted : 03/05/2013 6:48 am
