anyone know where (apart from NASA) I can get replacement bearings for sram x0 front hub?
Can't you just get the codes off them and speak to a bearing supplier?
Fraid not they are a non standard bearing have already tried that
Tried Fisher(Importer) or a SRAM dealer?
Yep tried both no joy, seems they don't know what they are selling to us !!
Well I'd suggest an e-mail to SRAM tech.
Not sure if you've got the 2015 spec hubs, but from the following page:
https://www.sram.com/sram/mountain/products/sram-x0-hub
the XO Service manual (page 12) seems to refer to 6803 and 68303 bearing press tools. And the Spare Catalogue (page 34) seems to refer to 6903 for the rear hub. Both mention a 23327 bearing.
There are also SRAM part numbers, so someone should be able to tell you what they are. I'd be really surprised if standard bearing notation wasn't inscribed on the seal rings...
If this is for a shop in Somerset then the bearings are en route Nigel.
Happy trails.
Is [url= http://www.veloruf.de/n/Sram.html?id=50000143&art=95580599 ]this[/url] it?
Hi Pauly, bearings have arrived, many thanks for your help 😀
many thanks to Fisher Outdoor Leisure for a rapid solution to my problems
Pleasure.
