Sram wavy washer on...
[Closed] Sram wavy washer on sram cranks?
5 Users
I recently bought a set of XO1 cranks s/h on Ebay.
Nothing included apart from both crank arms and spider/ring.
How important is the wavy washer and any other spacers or washers needed while putting these on?
Thanks,
Max
Posted : 28/12/2015 5:53 pm
needed as they take up any play, the SRAM crank are done up tight to a stop, so the spacers are use depending on frame/bb types.
Where the shimano cranks you "preload" as you can take all the play out and over tighten the BB.
Good friendly LBS might have some old spacers/washer kicking about as they do come in handy now and then.
Posted : 28/12/2015 6:07 pm
The wavy washer is important to take up the preload on the bearings, I think however it normally comes with the bb? you could use without but there maybe a little play in the axle.
Posted : 28/12/2015 6:08 pm
Ok guys,
I will put out a wanted ad and try and get some!
Thanks,
Max
Posted : 28/12/2015 7:21 pm
Hope it's not that important, I binned mine! No play in the cranks so fingers crossed.
Posted : 28/12/2015 7:40 pm
The Wavy washer is pretty unimportant... well depends on the BB. Only pressfit ones use them, and they are only to hold the DS bearing cover on essentially - they aren't strong enough to do much more although they do help to maintain the centre of the cranks too. If you need one, a 24mm inner o-ring of the right size works as well. Depends on the BB what diameter/thickness you need though.
EDIT: So point being the washer comes with the BB.
Posted : 28/12/2015 9:12 pm
Ahh,
I have seen that they are available through Wheels Manufacturing.
I will be buying a new bb as current one is Shimano.
Probably gonna go for a Hope though,mite come with it?
Mine is a PF92 if that's a help.
Thanks,
Max
Posted : 28/12/2015 10:25 pm
if you go for the Hope, you'll need the GXP adapters too.
Posted : 28/12/2015 10:28 pm
Even for press fit?
Thought they mite do a specfic bb for pf92?
Max
Posted : 10/01/2016 6:19 pm
