SRAM Type 2.1 clutc...
[Closed] SRAM Type 2.1 clutch adjustment?
3 Users
Apparently SRAM made it substantially harder to adjust the clutch on Type 2.1 derailleurs by putting a pin through the cap.
I have read conflicting accounts as to how to remove the pin to allow adjustment without destroying the clutch housing. It is protruding very little, so I can't pull it with pliers and I couldn't push it through the cap.
Any ideas? It's a newish XX1, but the clutch feels much, much, much softer than on my very used and bused Zee.
[url= https://i.imgur.com/TGWQH3Zl.jp g" target="_blank">https://i.imgur.com/TGWQH3Zl.jp g"/> [/img][/url]
Posted : 21/07/2017 11:45 pm
I didn't think that the clutch mechanism on SRAM rear mechs is adjustable like the Shimano ones. It is simply just set as is.
Posted : 22/07/2017 7:20 am
You totally can. The cap actually accepts Torx T55 key and turning it tightens/frees the clutch on Type 2. On type 2.1 that pin prevents it from turning, unless removed first.
Posted : 22/07/2017 8:27 am
Well the previous Type 2 was adjustable
http://forums.mtbr.com/drivetrain-shifters-derailleurs-cranks/adjusting-sram-type-2-clutch-868787.html
and serviceable
http://www.mtbiking.com.au/workshop/sram-type-2-derailleur-clutch-overhaul
but note the disclaimer that 2.1 is no longer serviceable or adjustable with that method.
Posted : 22/07/2017 8:36 am
