Are these mega specific (as I suspect) or does anything else fit?
Thanks!
That should be SRAM dub b/brk!
You are looking to replace a SRAM DUB BB like link below with another make of DUB BB ? Threaded or Pressfit ?
https://www.decathlon.co.uk/p/bottom-bracket-bsa-68-73-mm-dub-sram/_/R-p-202022
Nukeproof version https://www.chainreactioncycles.com/nukeproof-horizon-bottom-bracket-sram-dub-bsa/rp-prod187151
Uberbike version
https://www.uberbikecomponents.com/category/518/SRAM-DUB-Compatible-Bottom-Brackets
Hope do a DUB converter for their 30mm BBs search for 'Hope DUB Bottom Bracket conversion'
Fancy a Cane Creek ?
Or did you mean you wanted a a non-SRAM crank to go with your SRAM DUB BB ?
If so, not sure I have seen a DUB crank made by anyone other than SRAM.
Hi - it’s a SRAM DUB crank with pressfit bottom bracket
All the makes above do press fit too.
Does it give you the answers you were looking for ?
