Sram shimano mech c...
[Closed] Sram shimano mech compatability
6 Users
Hi Sram mech exploded climbing Dumyat today on Ebike is it still the case if I go to shimano on rear mech I have to change the shifter also. Bike is 12 speed if that makes any difference.
Cheers Mark
Posted : 18/07/2020 5:59 pm
 Neb
I'm using a SRAM 11s shifter with a Shimano 12s rear mech, it works fine. The clutch is better too!
Posted : 18/07/2020 7:46 pm
Maybe just get the mech then
Posted : 18/07/2020 9:10 pm
I believe that with 12 speed stuff, it's all close enough that it's viewed by many as interchangable, but not optimised.
Posted : 18/07/2020 10:07 pm
I junked my Sram GX rear mech last week.
Everything else is GX, shifter, Chain, cassette.
Fitted a new Deore 12 Speed, works flawlessly, better shifting than I ever remember with the GX.
It's lower profile than GX so should be out of the way of rocks, and hopefully less fussy about having a perfectly straight hanger.
Also at £38 is a helluva lot cheaper than GX.
Posted : 18/07/2020 10:12 pm
Outer cable needs to be a few cm longer, but mine was too long anyway.
Posted : 18/07/2020 10:15 pm
Currently running a GX Shifter with an XT mech, SLX cassette and a GX chain, works beautifully.
Slowly evolving from SRAM to Shimano.
Posted : 18/07/2020 10:28 pm
Replaced a 12spd GX mech with XT. As above it works just fine, shifts more consistently actually.
Posted : 18/07/2020 10:41 pm
Perfect a shimano one it is then
Posted : 19/07/2020 8:56 am
