sram/ shimano 12 sp...
sram/ shimano 12 speed compatibility ..... groan...
7 Users
2 Reactions
Bear with me please...treated my  son to a new bike as his old voodoo was falling apart.. got him a cube analog with sram 12 speed gearing..  32 chain ring.. and  11-51 T cassette.
However for the riding he does, mainly  road and a bit of  gravel that he rides around Cardiff he claims that he's only using the  smallest 3 rings on the cassette, everything  else is far too "spinning like a hamster wheel" for his liking.
The cassette is the lowest in the sram range so its hyperglidesplined.. so would a  12 speed road shimano  cassette, 11- 34 / 11- 36 work? I've been trawling the web but  cant find anything about the actual spacing between cassette rings to confirm this.. I know the 11 speed cassettes were inter changeable... plus he's 130 miles away so cant exactly pop over to check.
Cheers in advance..
Posted : 25/06/2025 7:45 pm
He’ll still only use the 3 smallest sprockets. Will the bike take a bigger chain ring?
Posted : 25/06/2025 8:16 pm
MicArms reacted
 cp
Bigger chain ring is what you need
Posted : 25/06/2025 8:19 pm
MicArms reacted
Alternative approach, get him some more draggy tyres.
Posted : 26/06/2025 7:16 am
Why does he need more gears/gearing ? As long as it's not an issue, even 1 is fine as long as it does the job.
Posted : 26/06/2025 7:18 am
 nre
MTB mechs are very much designed around wide ratio cassettes these days, fitting a smaller cassette will likely lead to fairly poor shifting as the upper jockey wheel will sit a long way from the cassette in the larger sprockets. Bigger chain ring is definitely the best bet!
Posted : 26/06/2025 7:37 am
only worry about it if he is actually spinning out the hardest gear... in all honesty keeping an MTB 15-20mph on the road (where i find these start to spin out) is bloody hard work.. if he can spin out regularly, buy a cheap chainring (ebay/amazon)
let him wear the cassette out
Posted : 26/06/2025 8:10 am
