Sram / Shimano 11sp...
[Closed] Sram / Shimano 11sp shifters.
5 Users
I read a post on here over the weekend that has got me thinking.
Do both these systems have the the same cable pull and are therefor interchangeable.
I have a full x01 system but i have always prefered shimano shifters.
So you see where i am going with this 🙂
i have 2 mechs so until i mash them ill stick with X01 but i would like to run a shimano shifter if possible.
Posted : 02/02/2015 9:14 pm
Buy a 11sp XTR mech and 11 speed XTr shifter. Swap them over, index, go ride!
Posted : 02/02/2015 10:15 pm
so the obvious solution is
Posted : 02/02/2015 10:18 pm
What I was trying to say was...rather than mess about trying to make SRAM and Shimano Mech and Shifter, sell the SRAM Mechs and buy Xtr mech and shifter. You have the range of SRAM with the shifting of Xtr.
I almost certain the ratios are still different so you will struggle to get the SRAM mech with shimano shifter to work correctly.
Posted : 02/02/2015 11:08 pm
Adam_buckland of this parish is using a Shimano shifter with SRAM mech, both 11 speed, and says it works perfectly. Surprisingly.
Posted : 03/02/2015 7:49 am
pbooker1995 - yep i get what you are saying but when i have 2 expensive x01 mechs in the garage i am not going to buy an XTR and shifter on top as my funds really don't stretch that far. I had read a post on here where someone was running this set up and just got to pondering if there was a chance of running a Shimano shifter with SRAM mech. Now funds could stretch to a new shimano mech 🙂
njee20, cheers buddy.
Posted : 03/02/2015 8:41 am
Njee20 is almost right, I run an XTR cassette and mech with an 11spd XO1 Gripshift and yes it works perfectly (I was quite surprised, I was a little concerned that the it may have been an expensive experiment). It seems the cable pull and spacing is exactly the same between SRAM and Shimano.
This might be of interest to you OP (if a little cheeky on my behalf), as I wasn't sure if it would work with the SRAM shifter I also ordered an Ispec 2 XTR M9000 rear shifter which is still sat in it's box totally unused - if you're interested drop me a mail at adam.buckland(at)Hotmail.co.uk and you can have it posted for £50.00
Posted : 03/02/2015 9:34 am
