SRAM Rival 2x to 1x...
[Closed] SRAM Rival 2x to 1x conversation
2 Users
Hello is converting from a 2x to a 1x drivetrain as simple as removing the front derailleur (leaving a redundant shifter)and swapping the chainrings to a singular narrow wide or am I missing something
Thanks in advance
Posted : 08/01/2022 9:27 am
Generally, yes, although it can be a little bit faffy to set up. You will probably need to play with the chainline a bit by setting up the chainring position. You want that to be sitting in a line with the middle sprocket on the cassette.
The chain may need some tension added to it by adjusting the chain length/b-screw. I've rarely had to resort to a chain guide.
Posted : 08/01/2022 12:28 pm
