SRAM rear mechs tha...
[Closed] SRAM rear mechs that are non clutch ? ( 1x for Gravel)
6 Users
Currently running Force CX1 11spd drop bar brake /shifter with Apex clutch rear mech, 1x with 11-40t cassette. I'd like to try a mech without a clutch (or one with adjustable clutch)but cant work whats available / compatible, regarding shift ratios for anything non-clutch but with a med/long cage.
The SRAM guide things dont seem to show what I'm after.
Posted : 04/05/2019 12:59 pm
Why do you want one without a clutch?
(Just curious).
Posted : 04/05/2019 3:29 pm
Depending on version you can loosen / tighten sram clutch with a large torx bit
Posted : 04/05/2019 3:33 pm
Its really grindy in the wet grit I often ride in, normal mech would be less so.
Posted : 04/05/2019 3:34 pm
Why less grindy?
Posted : 04/05/2019 6:03 pm
Yeah, I'm a little confused too op?
Posted : 04/05/2019 6:05 pm
Its nasty grindy.
Posted : 04/05/2019 7:36 pm
Not sure what else is available but I sometimes wonder if the extra tension of the clutch mech increases drag in the drive chain. It is usually on a draggy climb when I start wondering this, so it could be just gravity messing with my head.
Posted : 04/05/2019 7:43 pm
