SRAM Next Rally car...
[Closed] SRAM Next Rally carbon crank wobbly insert
8 Users
I know this has been done loads of times ......... but what was the recommended epoxy to fix the wobbly insert issue? These were a replacement for Next SL which also failed, have lasted about 18 months.
I'm trying for another warranty replacement but ultimately carbon cranks don't seem to work for me at 15 ish stone, although SRAM ones may be better?
Posted : 31/03/2019 9:03 pm
Sram ones were fine for me and I was a bit heavier. Race Face seem to be made of wet cardboard 🙂
Posted : 31/03/2019 9:23 pm
Dp420
Posted : 31/03/2019 9:35 pm
You could glue it back in with labrador spunk and it'll still be stronger than my Next SLs were.
Posted : 31/03/2019 11:19 pm
PS sram ones are 70 quid on wiggle right now
Posted : 31/03/2019 11:28 pm
Ok, I'm probably being dumb here but do you mean Race Face, rather than SRAM op?
Posted : 31/03/2019 11:39 pm
nope you're not being thick - I am
They are Race Face
Posted : 01/04/2019 9:40 am
mickmcd - which SRAM ones are they? thanks
Posted : 01/04/2019 9:41 am
They are the X1 carbon ones, you can get an extra £10 off as a new customer bringing them down to £59.99
https://www.wiggle.co.uk/sram-x1-eagle-gxp-boost-crankset/
Posted : 01/04/2019 9:44 am
https://www.wiggle.co.uk/sram-xx1-eagle-gxp-crankset/
Got mine for 119 they seem to have gone up a bit
Still use a new email and 146.99
Posted : 01/04/2019 9:51 am
does GXP work with a pressfit BB30 bottom bracket?? or do you need a GXP b/b which I think is screw in?
Posted : 01/04/2019 10:50 am
don't know chap i had a some plastic shims for the sram red gxp cranks we fitted dunno if the shoulder distances and chainline would be the same
Posted : 01/04/2019 12:55 pm
When we were looking the hope PF could be adapted, not cheap but probably worth it.
Running their PF bottom brackets in a couple of bikes with SRAM XO BB30 cranks and I think we were told they could be adapted for GXP if needed. Might be worth giving the tech dept a ring
Posted : 01/04/2019 1:03 pm
is dp 420 stuff very runny then? ie will it run into the tiny gap around the insert? thanks
Posted : 02/04/2019 5:31 pm
We have had two sets of the X1 Carbons delivered today, though they were a better bargain than just buying the chain ring that Abigale damaged on the rocks in Taz, just waiting on the chain and chain guard to get the bike back in working order. Might fit a new cassette at the same time. Won't know the full extent of the damage till the bike is built back up and can run through the gears.
Posted : 02/04/2019 7:33 pm
Dp420 is adhesive by its nature it's quite thick for various reasons
When I fix these I have a pedal axle to pull the insert square but not tightened , then drill a 3mm hole and I inject the glue from the end , thin runny epoxy might work but you struggle to get it in through the gap of the carbon skin and the insert.
Posted : 02/04/2019 8:09 pm
Why are those X1's so cheap at £69??
Sorry to butt in op.
Have RF Turbines, great cranks but 30mmm spindle which really limit my BB choice on a PF92 frame...
I might get those X1's for when my Hope (non serviceable...) BB fails and go 24mm which gives me much more BB choice. Ie BB's that are actually serviceable rather than pressing/swapping the whole bb out.
Posted : 02/04/2019 10:48 pm
x1 is a non series OEM crank...
Posted : 02/04/2019 10:51 pm
Cheers mate.👍
Posted : 02/04/2019 10:54 pm
Is that X1 not a picture of the X1 1400 crank (ie aluminium)? There is an eagle x1 carbon crank but I don't think that's a photo of it. (could be wrong photo)
Posted : 03/04/2019 2:15 am
Ours that arrived yesterday are carbon cranks and the chain ring looks the same as our X0 chain ring its not the same as a GX chain ring. Ours came from Wiggle but Chain Reaction have them in. I rang them to get confirmation that they were carbon and a 3mm offset before I ordered. At that price they are a steal taking into account what we would have had to pay for a XO chainring.
Posted : 03/04/2019 7:43 am
Looks something like this pic I think, photo on website is wrong, probably why they haven't sold out yet
Posted : 03/04/2019 8:31 am
Thanks!
How do you get £10 off as a new customer? I can only see the £5 for signing up to the newsletter.
Posted : 03/04/2019 7:37 pm
Oh wait I got it- NEWGB for a tenner off. Sorted, ordered, haven't had carbon cranks since last time I had carbon cranks and killed them 🙂 Tartiness increases, cheers!
Posted : 03/04/2019 7:42 pm
 rt60
Can you use the boost chainring on a non boost frame?
Posted : 03/04/2019 8:09 pm
Yes but chain line may be less than great.
Posted : 03/04/2019 8:13 pm
@mickmcd
How do you inject the goo? With a syringe? Thanks
Posted : 07/04/2019 10:29 am
Yes, although it can be a messy business loading and injecting epoxy with syringes and you will be limited in how fine a nozzle it will pass through Professionals have pump guns with mixer nozzles that make it much easier.
You can also warm the epoxy slightly to help it flow on a cold day but be aware that it will also shorten the curing time. Ultrasonic agitation will help any bubbles come to the surface. A sonic toothbrush held to the part can substitute, using an old head.
Posted : 07/04/2019 11:16 am
I have drawers full of them
Pragmatic answer is that will set you back more than a new set of cranks gun alone 50 quid adhesive 30 quid .
Posted : 07/04/2019 12:48 pm
