Yo,
Is there a clamp that I can mount both my XX front shifter and my Reverb remote (left side, under bar) lever to??
I’m thinking not...? Haha cheers guys
The Reverb remote is supposed to be mounted above the bars (i.e. either move yours to the right side or buy a left-handed one).
Or, you know, go 1X.
AFAIK official MMX solutions are limited to one 'thing' plus brake on the clamp -- so you can have a shifter or a remote of some sort but not both. If you run a front shifter, that basically forces you to decide which you want to integrate.
Cheers boys, I’m with ya. If I can integrate the shifter onto the brake at least, I’ll have a bit more space for the reverbs own clamp.
[i]Or, you know, go 1X.[/i]
Or Grip Shift 😉
Can you run it over the bar? In which case just get a regular MMX remote, will take shifter and brakes if they are sram too on one clamp.
Not a big deal to fit, just need a bleed kit and fluid which you normally get with the post anyway.
