Sram / hope chainri...
[Closed] Sram / hope chainring compatibility
6 Users
hi
I ride a codeine with sram X11 crankset, I recently purchased an 1x11 narrow hope 34t chainring and dropped it at the LBS to swap it over. A day later I get a call telling me won't fit ?, and need to get a sram one ?, never heard of this.....its a small shop but is this the case ? , after shelling out £40 notes is bad enough but I'm looking at another £55 for a sram one.
Any help appreciated, as ever
Kev
Posted : 28/08/2015 10:09 pm
They're right, funny that!
Insomuch as it won't fit, the hope one will be 104mm bcd, and the X1 crank is 94mm bcd, Google away to find an appropriate chain ring, doesn't have to be a SRAM as such
Posted : 28/08/2015 10:13 pm
Yes it true sram spider only compatable to sram chainring, worth spending a bit more and put a different spider on then you can put any other chainring on in future as opposed to having to use sram only
Posted : 28/08/2015 10:17 pm
Yes they are right not just trying to rip you off...
You can get a raceface direct mount one for £55 and remove the spider and save weight.
Posted : 28/08/2015 10:28 pm
Thanks gents, much appreciated !!!
Kev
Posted : 28/08/2015 11:07 pm
So is it possible to remove the spider on a SRAM XO1 crank to enable direct mounts to fi? If so how does the spider come off?? Ta
Posted : 29/08/2015 7:03 pm
You undo the 3 Torx bolts keeping it in place:
Posted : 29/08/2015 8:15 pm
So if I remove the XO spider can I then fit direct mount chain rings??
Posted : 30/08/2015 5:33 pm
Yep
Posted : 30/08/2015 5:52 pm
Happy days cheers fellas
Posted : 30/08/2015 6:02 pm
Just remembered I have sram X1 crankset. Would the same apply??
Posted : 30/08/2015 7:54 pm
