SRAM Guide RS grubs...
[Closed] SRAM Guide RS grubscrew spares?
6 Users
Having dis assembled my Guide RS master brake cylinder, i have dropped and lost a grub screw that holds the brake lever pivot.
Does anyone know where i can source one as i cant use the brake without it....argh
Thanks
Ian
Posted : 07/06/2020 1:04 am
No one? Do i have to buy a full £30 service kit?
Posted : 07/06/2020 3:07 pm
SJS is my usual go-to for SRAM spares, although you usually have to get more than you need and then pay as much again on postage...
https://www.sjscycles.co.uk/search/?term=sram%20brake%20spares
Posted : 07/06/2020 3:23 pm
Ive a 2015 rsc lever that the piston had gone on somewhere in the spares bin , would the screw fit from that & how easy is it to take apart ?
Posted : 07/06/2020 3:29 pm
Its super easy to take apart. There are grub screws behind the lever that tale a 2 or 2.5mm Allen key. Its one of those grub screws i have dropped amd lost.
Ian
Posted : 07/06/2020 3:45 pm
I'm guessing the R's dont have this grub screw matey?
Posted : 07/06/2020 8:51 pm
Im not sure about the R version. There is definatwly one for the main brale lever pivot and in the RS version there is another for the pivot of the 'servo wave' mechanism. Both the grubscrews are the same.
Posted : 07/06/2020 9:02 pm
Sram tend to sell lever kits, rather than individual parts.
Is it a special grub screw? Or could you just buy a M1.6/2/2.5/3/4 etc grub screw with cup or point in the correct length from ebay?
Posted : 07/06/2020 9:11 pm
sorry will check in the morning after the school run pretty sure have one
Posted : 07/06/2020 9:12 pm
All, thanks for this help.
Ian
Posted : 07/06/2020 10:40 pm
The Rs don't have that bit, if it's any help. The lever pivot is just pressed in.
Posted : 08/06/2020 6:45 am
