Sram Guide R Brake ...
[Closed] Sram Guide R Brake pads
8 Users
Can anyone recommend some good all round pads tha don't cost the earth?
Posted : 20/05/2018 9:13 am
Uberbike Race Matrix.
Used to be Superstar Kevlar pads for me, but they've given up making (importing from China) pads (and grips).
Posted : 20/05/2018 9:47 am
I also use Uberbike Race Matrix pads. Better than the originals for me, just as strong and (mostly) squeal-free, hard-wearing, not expensive.
Posted : 20/05/2018 10:06 am
CRC were discounting the OE pads at a tenner a pop,just checked and theyre back to £20 again now
Just as well I bought a discounted set with every order then !
Posted : 20/05/2018 10:19 am
Another Race Matrix user here, felt great on my RSCs.
Posted : 20/05/2018 10:24 am
Currently using Gorilla pads, seem to work well give that they cost £5 per brake
https://gorillabrakes.com/product-category/avid-brake-pads/
Posted : 20/05/2018 10:32 am
Uberbyke it is then....does my rotor look knackered?
Posted : 20/05/2018 11:21 am
I have no idea if this is the correct thing to do but I occasionally get some fine (600 grade or finer) wet and dry sandpaper and damp sand the rotor to remove grime etc - I reckon that'll be fine.
Posted : 20/05/2018 11:23 am
IPA (not the beer 😁 ) will clean up rotors, and good for cleaning all kinds of stuff.
If there's no worn notch between the braking surface and the rotor arms then they'll be good. If there is, still may be life in them, just pads may have slightly further to go to grip. Given a lot of third party pads I find are a bit thick and I have to sand them down sometimes, maybe not much of a problem.
I tend to only replace rotors when I'm replacing brakes.
Posted : 20/05/2018 12:34 pm
I assume you mean Isopropyl Alocohol, in which case I concur.
Posted : 20/05/2018 1:58 pm
15% off at Uber at the mo too......
I use their Racematrix, excellent pads.
Posted : 20/05/2018 10:38 pm
Bike24, SRAM OEM no springs or bolt but cheap.
Posted : 20/05/2018 11:45 pm
