SRAM Guide R bleed ...
SRAM Guide R bleed block width
5 Users
I have some SRAM Guide R brakes in need of a bleed. They have the bleeding edge port so I think that means they are the most recent. Does anyone know for certain what the correct bleed block width is?
Any suggestions on where to get one at a reasonable price!
Posted : 01/09/2022 3:44 pm
Shimano ones fit if that helps, I imagine any manufacturers would fit, the differences in pad/rotor thickness are fractions of a mm.
It doesn't really matter, as long as the pistons aren't able to come out more than a smidgen. On most brakes I just take an old set of pads and jam whatever I have to hand between them.
Posted : 01/09/2022 4:48 pm
I have a few spares. PM your address and I can post you one.
Posted : 01/09/2022 5:05 pm
Get one of these
https://www.r3pro.co.uk/collections/bike-accessories/products/bleed-block-and-spacer-tool-for-sram-guide-brakes
Allows you to set the spacing to how you like the brakes to feel. Good build quality.
Posted : 01/09/2022 6:41 pm
Won’t the pads automatically reset the first time you apply the brake?
My Guide rear pads rub lightly but enough to make a noise. Bought the eBay version of the metal spacer tool but can’t even get it to go between pads and rotor.
Posted : 03/09/2022 10:00 am
