SRAM eagle 12S quic...
[Closed] SRAM eagle 12S quick link on a shimano 12S chain?
2 Users
Dear STW hive mind, I have googled this, but I'm confused and I don't want to die in a puff of quicklinks.
I have Shimano 12S quicklinks - I have SRAM Golden rainbow 12 Speed quicklinks.
I want to be able to split the chain on a fairly regularly basic to dip in Putoline. ( I know - I know)
Do I fit the one use Shimano and get on with my life or fit the non Shimano SRAM quick link, that it appears you can reuse?
Having a cuppa - before I fit....
Reads like I can
12-speed Shimano SM-CN910-12 5.25mm
SRAM EAGLE Chain Connector 12-speed Power Link 5.25mm
Posted : 13/05/2022 6:51 pm
I'm pretty sure you aren't supposed to re-use SRAM 12 speed links too... though I have done. They do get a bit loose over time though.
Aren't Shim chains/ cassettes now fundamentally different in their 12 speed design anyway meaning the sram link might cause issues? Only way to see if the link works is to try it I suppose.
Posted : 13/05/2022 10:12 pm
