SRAM Connectamajig
[Closed] SRAM Connectamajig
5 Users
 aP
Does anyone know anything about these?
I will need to get a brake hose shortened which has this new "tekkernology". Are shops up to speed on this yet? Or will I be treated to "early adopter" shenanigans?
Posted : 23/10/2015 11:59 am
 aP
No one?
Posted : 24/10/2015 12:25 pm
Shorten at lever end, screw threaded barb back onto shortened hose. No need to touch connectamajig. I haven't and I've fitted my stealth post twice
I suspect it is a device that allows assembly of bikes with stealth posts removing the need to bleed them at the factory
Posted : 24/10/2015 12:46 pm
Been around for a good while now so no issues with shops doing the work.
Posted : 24/10/2015 1:22 pm
And swapping brakes over from Euro to UK. My Rival-equipped SuperX has em and Shimano use em too now (Munqechick's Focus CX with Ultegra has em).
Posted : 24/10/2015 1:57 pm
The connectamajig can be taken off and refitted if required but as above better to unscrew at lever end and cut/refit.
I've just replaced a reverb with one which didn't have a connectamajig from one that did. It was a simple job of removing the connectamajig from the old reverb and refitting it to the replacement, which saved me having to redo the internal stealth routing.
Posted : 24/10/2015 6:31 pm
 aP
Thanks, what worries me slightly is its brakes rather than dropper post, I'd rather not get into the complicated word of bleeding.....
Posted : 24/10/2015 6:46 pm
It's fairly straightforward to bleed provided you have the SRAM syringes.
Posted : 24/10/2015 6:59 pm
