Hi all..
any ideas if this will fit my X0 crankset.. as it works out cheaper than buying rings,unless someone can suggest 39-26T rings or below cheaper than this!
thanks
Bruce
I'm assuming you missed out some sort of link?
Some sort of spider & rings? Also need to know if you original is a 120 or 104 BCD, to compare rings costs (Assuming XO come in the 104 flavour like X9/X7)
http://www.chainreactioncycles.com/sram-xx-chainring-spider/rp-prod42790 This ones... Spinder and rings.. 120-80 is the original
thanks
Bruce
There a chance the spider might not fit, but no reason why the rings shouldn't fit & work, as they run the same chainline. Only thing to bear in mind is the outer rings "pin" maybe too long, but a file would deal with that, but is it's too short, there a small chance the chain could get between the outer chainring and crank arm & causing damage (relatively small chance).
