Sram code hose
[Closed] Sram code hose
2 Users
I've bought myself some code r brakes, replacing my internally routed levels. The code uses a ring type connector on the caliper, but the level used a compression type. Is there a way of fitting a ring connector onto the already in place hose, or do I need to buy a new hose and go through the faff of threading it through the frame?
I've seen a hope adapter for sale, will that work with my codes?
Posted : 22/01/2020 9:23 pm
New hose needed.
Posted : 22/01/2020 9:26 pm
Boo
Posted : 22/01/2020 9:38 pm
Sorry. If it makes you feel better I only know as I just changed mine.
You get all the bits you need in the box to easily attach the new hose to the old one and pull it through.
Posted : 22/01/2020 9:40 pm
https://www.chainreactioncycles.com/mobile/hope-hose-connector/rp-prod3257
Not one of these?
Posted : 22/01/2020 9:41 pm
Ok fair enough, new hose it is then
Posted : 22/01/2020 9:44 pm
Not one of those, get your new hose
Posted : 22/01/2020 10:17 pm
