SRAM CODE brake hos...
SRAM CODE brake hose
6 Users
2 Reactions
I know there was a thread on the high price code brake hoses, that thread has been closed.
So I have guide ultimates on my main bike and I want to switch out the guide callipers for codes. I picked up cheap set of code r without hoses with the view of running them with the ultimate levers.
I’ve seen that there are replacement banjos available for around £5 but I can’t determine whether they are compatible - or I can a generic hose from eBay that is advertised as levels & code compatible.
Those of you who were asking, what was your outcome?
Thanks
Posted : 15/01/2025 4:09 pm
Needs to be a code hose and specific fittings. Had this problem a while ago.
Posted : 15/01/2025 10:28 pm
The stealthamajig barbs and bango fitting work with any sram code brakes. Get them from a reputable supplier though as lots of fakes about that end up with brake fluid leakage at the connections. Also invest in a cheap cable cutter to make it easier to cut cable perpendicular. Cable itself is fairly generic but you only lose 1cm if you chop off old barbs and use existing cables.
Posted : 15/01/2025 10:30 pm
I've used Superstar fittings on my codes without any problems whatsoever.
Posted : 15/01/2025 10:37 pm
My memory isn't great but I think you can use Code calipers with Guide hoses, but not the other way round.
I have mixed the hoses and calipers, but it only works one way.
Posted : 15/01/2025 10:49 pm
Thanks for the replies..
What I've found so far;
  1. Superstar no longer seem to sell brake hoses, can find anything on their site
  2. Not only is the banjo bolt difference so is the banjo it's self. With the Codes the head of the banjo bolt sits flush with the head, where as the guides the bolt sits on it  sram-g2-brake-review-test-6-600x400
So I can't imagine that will fit the other.
The only other option I can find is from Uberbike, they have a banjo kit. I'll have to call them tomorrow to ask about compatibility, to the calliper and the Sram hose. Otherwise I may as well just buy the Sram Code hose and be done with it.
Posted : 19/01/2025 6:22 pm
You need to know if you need a silver banjo or black.
Code hoses will state on the packet what it has.
Posted : 20/01/2025 8:16 am
But did the brake work with the Guide hose ?
I am sure it did for me.
Posted : 20/01/2025 8:25 am
So after searching and searching I bought these on the off chance that they would fit
https://a.aliexpress.com/_Ew5nDe A" target="_blank" rel="noopener">Banjo fitting
they do fit, I didn’t use the ‘o’ rings because the seller couldn’t tell me if they were made of EPDM, so I thought it safer to reuse the ones that where originally fitted.
Anyway it’s a good option if you have CODE brakes and need new hoses and can’t get the ones with the correct banjos.
Have been running the CODE callipers for a while, they are a big improvement over the guide callipers.
Posted : 26/05/2025 2:54 pm
