Sram Bleeding Edge ...
[Closed] Sram Bleeding Edge Woes
9 Users
Anyone else have a nightmare using this new bleeding edge tool thing?  It doesn’t seem to create an air tight seal around the port. It’s absolutely shocking. I need at least another 12 pairs of hands!  Grrrrrr
Just me?
Posted : 29/07/2018 8:14 pm
You definitely felt the click when you push it in? have to push it quite firmly
Always works ok for me
Posted : 29/07/2018 8:16 pm
Never had an issue.   You have to push it really hard to make it click in.
Posted : 29/07/2018 8:25 pm
Never had an issue either, I think it's good.
Posted : 29/07/2018 8:26 pm
When you say make it click, the rubber o ring is inside the port and it engages well when turning to unscrew the bleed port?  Should there be another click?
Posted : 29/07/2018 8:27 pm
Yep you can still open the port without it being properly engaged. You should feel a clear click when it's in.
Posted : 29/07/2018 8:32 pm
Oh bloody hell. I’ll try harder next time!  I swear my reverb has more air in it now than it did before I started!
Posted : 29/07/2018 8:34 pm
So far it's worked fine for me on a reverb but I don't really see much advantage and I was very conscious that the thing could easily come out at an inopportune moment. In fact what is the point of bleeding edge?
Posted : 29/07/2018 9:29 pm
You can close of the port before removing the syringe, leading to less leakage / risk of air ingress.
Posted : 29/07/2018 9:37 pm
Worked ok for me the one time I’ve used it. Opened the port per the instructions then clicked the bleeding edge tool in. Pushed quite hard and you hear a big click as it engages.
Got a great bleed first time - wish the lever had the same thing so you don’t leak a bit of brake fluid when you disengage it at that end too.
Posted : 29/07/2018 9:50 pm
Do you ‘click’ it in before or after you turn the bleed screw?
Posted : 29/07/2018 10:07 pm
Before
Posted : 29/07/2018 10:10 pm
Reverbs dont have a defined click when pushing the bleeding edge tool in. Others are talking about the brake version.
Posted : 29/07/2018 10:13 pm
I’m using the reverb x1 remote if that makes a difference?
Posted : 29/07/2018 10:30 pm
