Squeeky cleats?
[Closed] Squeeky cleats?
7 Users
How long do Shimano Sh51 spd cleats last? What is their mechanism of failure?
I have a couple of pr of shoes usin these cleats and a selection of xt and Boardman team spd pedals. Recently they have started to squeek as they float in the mechanism.
I can stop it by rolling my foot outwards and bracing the cleat against the pedal mechanism.
Does this mean they are worn out? The cleats are a couple of yrs old and seem to release just fine, but the noise is now upsetting me.
Any thoughts?
Posted : 13/05/2020 3:43 pm
Brush a bit of chain lube onto your pedals with a toothbrush. Normally sorts it for a while in my experience.
Posted : 13/05/2020 3:45 pm
I have one squeaky cleat! My left foot sits slightly pigeon-toed when pedalling so moves a bit as the pedal goes round. The squeak drives me mad once I've tuned in to it.
A dab of thick grease on the spd mating surface before leaving home seems to last most of a ride. I've also found dabbing my cleat in a puddle fixes it for a bit (assuming you can find a puddle).
My cleats are years old. Been squeaking for years too. No other indication that they're worn out so living with it.
Posted : 13/05/2020 4:17 pm
WD40 on the cleats.
Posted : 13/05/2020 4:19 pm
Try loctite on the pedal springs, once it's dried it stops any squeaks or creaks for ages.
Posted : 13/05/2020 4:22 pm
The cleats should last way longer than the shoes you attach them to. I put new cleats on new shoes. I cant imaging the cleat fails unless you bash it on a rock and your foot is likely to fail before the cleat gets bashed out of shape.
Posted : 13/05/2020 4:25 pm
It's not the shoes is it?  I've had to trim off a small chunk of the sole rubber immediately around the cleat area on one pair.  Grease / lube did the trick for a short ride but the long-term solution was to get the stanley knife out.
Posted : 13/05/2020 4:29 pm
Ah, could be shoe/pedal interface?
I will check for any witness marks...
Posted : 13/05/2020 5:23 pm
