Squealing V-brakes!
[Closed] Squealing V-brakes!
4 Users
Have tried sanding the pads and cleaning pads and rims with degreaser but no joy
Anything else I can try short of replacing the pads?
Posted : 18/04/2011 11:28 am
Make sure the front of the pad hits the rim 1st, new brake blocks normally have a couple of 'pips' at the back so you can get the angle right.
BITD a strip of cereal box stuck under the last cm of block then lined up againt the rim worked well.
Posted : 18/04/2011 11:32 am
Thanks!
Posted : 18/04/2011 11:34 am
As MikeG says but I use a posties rubber band with a knot in then slip it over the back of the pad so the flat side of the band sits between the pad and rim. It stays in place unlike a piece of card that can fall out if you dont keep the pressure on the pad.
Posted : 18/04/2011 11:37 am
Red post office rubber band works much better as you don't have to hold it in place, [url= http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type ]Park Tools[/url]
Posted : 18/04/2011 11:39 am
Thats a good link, I've never used a laccy band but will give it a go next time I have to adjust the commuters brakes.
I do use a laccy band to pull the brakes on while adjusting, much easier to get them square if theres a bit of tension holding them against the rim (and it saves having to have 3 hands)
Posted : 18/04/2011 11:45 am
