Square Taper woes
[Closed] Square Taper woes
10 Users
tried removing an old ST BB from an old frame i want to "do up" a bit... all was going well, and there was a bit of movement from the BB when it suddenly let go and shattered the teeth (plastic) on the BB...
thoughts?
Posted : 20/08/2014 6:23 pm
That's just a cup, you can pull the whole BB from the drive side and with the load off that should come out.
Might be a good idea to get some penetrating oil into the shell first.
If it's really tight and you are using an open ended tool on the drive side you can put a penny washer and crank bolt in to stop it slipping out of the splines.
Posted : 20/08/2014 6:27 pm
Chisel the bugger out. (Carefully) you'll be wanting to get the threads chased afterwards mind.
Posted : 20/08/2014 6:30 pm
As Neil says. Pull it out from the other side then get a hacksaw blade and carefully cut through the cup (don't cut too deep!). Then use a slotted screwdriver, or any other tool, to prise the bits of stuck cup out.
Posted : 20/08/2014 6:32 pm
Ah, good to know, this is 1st ST I've tried to remove... Drive side is stuck fast though, & I didn't want to be too brutal given what happened on the non drive side!
Posted : 20/08/2014 6:34 pm
If it's plastic,it'll melt out. As said, get it out fromthe drive side, then just melt or carefully chisel it out. Plastic cups can be a pain, but owhere near as bad as seized metal oes.
Remeber to loosen the bolt off as the cu comes out though. If it comes out.
Posted : 20/08/2014 6:35 pm
Pour some thin oil down the seat tube and let it sit for a day or two, looks like it's been in there for a good while.
If you have access to a work bench, vice and the right tool, put the tool in the vice and use the frame for leverage.
Posted : 20/08/2014 6:41 pm
all good top tips, and yes, there's a bench vice at my mum and dads.. lovely stuff 😀
Posted : 20/08/2014 6:48 pm
Is the corrosion sticking out a bit right at the end of the thread? That might have stopped the cup enough to wreck it.
Posted : 20/08/2014 6:56 pm
possibly.... lokking at the pics (i'm at work right now) i can convince myself either way!!
Posted : 20/08/2014 7:14 pm
 JoeG
Bolt thru the BB tool and into the BB spindle to keep the drive side cup from slipping. Remember, drive side cup is reverse threaded!
Posted : 20/08/2014 7:54 pm
Use my tool tip to get the drive side out: [url= http://singletrackmag.com/forum/topic/stubborn-bottom-bracket-removal-tip ]Bottom bracket tool tip[/url].
Then you can get to work on the plastic cup. In my bike shop days I used to make two cuts with a hacksaw nearly all the way through the plastic and then just lever it out with a screwdriver. Then I would chase the threads with the Park threadchaser. Use lots of copper grease when fitting the new one!
Posted : 20/08/2014 8:28 pm
This
Posted : 20/08/2014 8:38 pm
As above, looking at the way the splines have deformed on the DS, you've been tightening it.
Posted : 20/08/2014 8:44 pm
