Could anyone on here make me a hollowtech 2 to square taper axle?
So I can use my Middleburn with external BB instead of internal?
I might buy your middleburn when you realise it can't be done as I've just gone back to square taper rather than external 🙂
[i]So I can use my Middleburn with external BB instead of internal?[/i]
the worst of all possible BB/crank combo worlds?
And no mechanism to pre-load the bearings.
Just get a Phil Woods square taper BB? cheaper and better.
Sounds horrendous. You'd have a really wide axle with a very abrupt step from 24mm round to go through the bearings to the square taper. As said no way to preload the bearings either.
I'll be blunt:
It won't work. Forget it.
Stick with one standard or another. There's not much wrong with HT2 or SQT, both have small disadvantages and big advantages.
